Results 1 to 7 of 7
Thread: POSSIBLE vipec issue with r32 gtr atessa
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    So I got a plug in vipec install this fall and since the installation, I have had constant intermittent losses of AWD due to a TPS fault which doesn't affect the ecu but only the atessa unit. Now, I'm not saying it's a vipec issue since we also replaced the intake plenum (removed the TPS to install) but some have said it may be.
    Anyways, I've found some information by a few others on SAU who had this issue with their GTRs with vipecs and autronic ECUs and found that the ecu was causing a slight voltage drop that faulted the atessa unit. I'm not the only Gtr owner with a vipec or autronic so have any others experienced weird AWD issues with the car? If this is a dead end, I have no choice but to start replacing parts as trouble shooting is getting trickier with the engine out. Thanks to those who may have some information. Worst case I ditch the AWD rofl.
    lol
    Jun 2008
    Alberta
    4,233
    Ok, got some more information.
    The V-88 was the one causing some issues so I'm back on the scratch pad. Should I kick the Atessa and drop to a 25 gearbox and pan? lol. Ongoing.... open to ideas, going to open the main harness and do some hard tests on it. Next will be TPS, then atessa unit.
    lol
    Mar 2005
    Calgary
    385
    Quote Originally Posted by NismoS-tune View Post
    I peronally think that the ATESSA system is the core of a GTR. That's the reason that GTRs won all those races in the past. So, I'd keep Atessa. Otherwise, I would just buy a GTS.
    GTRCer BNR32GTR's Avatar
    Sep 2009
    Edmonton, Alberta
    44
    Hey Franc,
    I'm curious to see what you find out, I also am looking at running a ViPec so it's nice to see what people are experiencing with them, this is one of the first problems i've heard with them.
    Keep thread updated !
    Corey.
    Jun 2008
    Alberta
    4,233
    Well, it's probably just a coincidence that the problem started happening when the vipec was installed.
    lol
    GTR-Dad's Avatar
    Dec 2005
    Beaumont, AB
    2,955
    My clutch pack was gradually dying, but ATTESA worked fine with my ViPEC.
    I've recently installed an OS Giken box with a new transfer case. The R32 speedo adaptation to the R33 box crapped out and currently reads zero all the time. This affects ATTESA!
    Dan
    The Beaumont Connection
    Willis's Avatar
    Jul 2006
    Whitecourt, AB
    513
    Sorry to bump an old thread but I was reading in my ViPec manal and in the back there is a "known issues" section.
    On some GTR and 4WD models a warning light may be displayed on the dash. This may be due to the value of the ECUs TPS Out signal level being too low. A solution to this is to slightly rotate the TPS to increase the closed throttle voltage. Remember to do a TPS cal after moving the TPS.
    So when you are on the dyno tuning and seting up a ViPec it might be best to get a higher closed voltage and a new Cal. Seems like an easy fix.
