Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: AMS INC 700 BHP R35 pt 1
    Vuk@AMS's Avatar
    Jul 2008
    Toronto
    288
    Working with Nissan's Flagships is one of our mainstays in addition to our prestige division (Porsche, Aston Martin etc). The next project illustrates a recent project on the almighty R35 and another first in Canada!
    This recent project involved a 2009 GTR with slightly over 10,000 kms on the dial. The task at hand was to be the first to rip the motor out within Canada and give the car some additional chest hair - approx 700 bhp!
    First off some pics of project:
    Pics of the engine bay:
    Special aluminum adapters on hand in conjunction with our standard rubber blocks:
    Removal of the engine requires dropping the engine from underneath along with the front sub-frame. The book value for this type of job is in the mid 30 hr range plus!
    Shot underneath the R35 with the panels, y-pipe and driveshafts off:
    Engine being extracted:
    Now to achieve the power goals a set of upgraded stock turbos was sourced - oversized wheels within stock housing. The manifolds and exhaust housing were ceremic coated as well!
    New turbos next to stockers:
    New Turbos mounted on the engine minus the shields:
    In addition to the turbos we added 800 cc injectors and an AMS R35 Race Pulley! Stock injectors are blue:
    Stock Crank Pulley before removal:
    New OEM Crank Seal was installed along with the industry first AMS R35 Race Pulley. More info on the pulley here:
    http://amszstore.com/main/product_in...roducts_id=222
    Some additional goodies are Special plugs and Ceramic coated DP's with high-flow cats:
    Upgraded suspension components (upgraded springs) pictured next to the stock units :
    To install the rear the entire panels and seats require removal:
    Some minor issues that were resolved eaily was some oxidizing on the main sub-frame bolts (pic before cleaning), interference with Samco lower rad hose with Samco Intercooler Hose and Performance Friction Pads that seperated (likely due to track abuse):
    PROVIDING FOR NISSAN'S FLAGSHIPS SINCE 1992!
    SEMA MEMBER & SEMA STREET PERFORMANCE COUNCIL MEMBER
    Vuk@AMS's Avatar
    Jul 2008
    Toronto
    288
    AMS INC 700 BHP R35 Build pt 2
    Now just for fun I took a few sneak peak shots of the Z1 1000R turbo kit (twin 3076's with Forge wastegates) mounted to AMS Max-Flow Manifolds next to the R35 Manis/turbos. These are being installed on our corporate Z32 this year along with a host of other parts:
    No clearance issue with the Z1 3076's and the AMS Max-Flow manifolds with the included shim and the use of two OEM gaskets on the driver side:
    The GTR recieved an upgraded flash from the Cobb accessport and was fired up! Idled smooth and purred like a kitten! Next up will be some data-logging and a custom tune on the dyno. Similar kits have yielded 700 bhp on pump gas so just a matter of how much boost and type of gas used if one desires more!
    Enjoy!
    Vuk@AMS
    1(888)888-AMSINC
    www.amszstore.com
    www.amsporsche.com
    www.amsmotorsports.com
    Apr 2008
    canada
    1,810
    Vuk, amazing work... im super proud that i own some AMS products. btw after a year of use, no rust, no corrosion and still perfect operation of my AMS front upper control arms.
    keep up the good work
    Vuk@AMS's Avatar
    Jul 2008
    Toronto
    288
    Thanks for the patronage
    You will be more than happy even with future offerings no doubt!
    Plenty of interesting products and projects we will post about as well!
    Regards,
    Vuk@AMS
    Quote Originally Posted by archaeic_bloke View Post
    GTRCer MikeRWK's Avatar
    Dec 2008
    Englishtown, Cape Breton
    1,266
    very nice!
    Proud owner of the 2nd Skyline and the only GTR on the island!
    Boost@14PSI, YellowJacket Coils, Extreme TSC, Full Nismo N1 Bodykit, Greddy Speed Cut Controller, HKS Turbo Timer, 280LPH Denso Fuel Pump, Nismo Slave Cylinder, AMS BOVs, Nismo Clutch Pivot, ACT Xtreme 6 Puck and HDPP, Greddy Panel Filter
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,113
    sweet build, incredible piece of machinery those GTRs
    and about new products
    a lightweight pulley kit for the RB we be wonderfull, i'd put money down right away for it :P
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,053
    beautiful build! nice job as always guys
    RightDrive Inc. Parts Manager
    $45 Off Mishimoto Radiators!
    RABBIT's Avatar
    Oct 2007
    Toronto
    3,167
    reallly want a light weight crank pulley soo badly.
    RB20DET[FTMFW]FOOLS//.
    Vuk@AMS's Avatar
    Jul 2008
    Toronto
    288
    Thanks guys!
    All new products will be announced and requests noted
    Regards
    Vuk@AMS
    1(888)888-AMSINC
    www.amszstore.com
    klys's Avatar
    Aug 2004
    Lachenaie Qc
    4,417
    hum .. just an insight
    you need an harmonic damper on the front end of the engine.
    I'm not too sure how safe very very light would be.
    Marc-André
    _________
    2.2L RB20 GTS-T
