Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Vr38dett Engine Dyno!!!
    May 2007
    Toronto
    635
    GTRCer Bruizer's Avatar
    Oct 2006
    1,504
    On that chart I see 600hp. Isn't the 08 GTR less than that? Then again, the specs say 480, that's pretty close.
    No build thread.
    1991 nissan
    El terror
    Dec 2005
    295
    Quote Originally Posted by Bruizer View Post
    That Chart is in NM(Newton meters) not ft.lbs.
    GTRCer mikey's Avatar
    Dec 2006
    Valleyfield, Quebec
    242
    wait a minute..... wouldn't you use NM for torque rating? and KW for power rating?
    So that means....456hp and 442lb/ft.
    I wish the old one's had torque ratings that close to the hp rating.
    Jun 2004
    Windsor, Canada
    1,992
    Quote Originally Posted by mikey View Post
    torque is a factor of dispacement and boost pressure.
    horsepower is a factor of torque x RPM.
    if you want to make more torque than horsepower, limit RPM's, or run small turbos that make lots of torque and not lots of horsepower.
    the RB26 is a small displacement, high revving motor. Add displacement or take away revs and you'll see similarly matched numbers.
    1992 GTR
    1988 Mazda RX-7 10AE
    1999 F250 Superduty 7.3L Turbo (tow vehicle)
    GTRCer flipridah17's Avatar
    Jan 2007
    Vancouver, BC
    2,171
    Quote Originally Posted by Terrh View Post
    Learn something new everyday..
    GTRCer TK-GTS's Avatar
    Jan 2008
    edmonton
    244
    technically there are no hp specs on the gtr since they are all different.
    60% of the time my car is on the road all the time.
    GTRCer Xeno-Vibe's Avatar
    Mar 2007
    S.Ontario (London)
    573
    Quote Originally Posted by TK-GTS View Post
    Are the differences just because they were hand made? Isn't that kinda crappy that you can have a stock GTR and your friend can have a stock GTR and yet it can be a huge difference in the specs?
    Its weird cause i thought it had 485 WHP stock but I've also seen youtube vids of the dyno chart said its only putting out 432 hp/424 ft-lb (this is just the most recent one i saw) Is there really that big of a gap?!?!
    Double track drift, yo.
    (oo sκylιnε oo)
    Oct 2007
    Toronto
    6
    Each dyno result is different, ie dynojet, dynapack, mustang etc. Along with other factors.
    GTRCer EliteGTR's Avatar
    Nov 2006
    Long Island, NY
    213
    This is on an engine dyno. As a far as each being different, I dont buy that. If they are assembled by hand using the same specs how much difference can there be? probably more consistent then machines doing it.
