Powerhouse Racing would like to offer probably the best and most complete kit that is turn key install!
This has EVERYTHING and I do mean EVERYTHING from the back of the car starting with the filters, pumps, Insulating Pump Wrap, washers, fittings, In-tank hose, clamps, Fuel Hat, -8AN Feed Line, Filter, Y Block, Fuel Rail, Injectors, Adapters, Injector Clips, Fuel Rail, Brackets, Fuel Pressure Regulator, Fuel Pressure Gauge, Custom Fittings, Fuel Pressure Gauge, -6AN Return Line.
This is ONE COMPLETE KIT!!!!
Pictures below are a 1000 words and will show you everything you need to know. Our fuel system uses stainless lines with a Teflon inner coating that will allow you to run E85 so that it wont allow moisture to enter the fuel line. We also have the Black anodized Rail and Weldon Fuel Pressure Regulator for an upgraded option.
PRICING WILL BE POSTED AT:
Stage 1 Fuel (750cc Injectors) - $2250
Stage 2 Fuel (1000cc Injectors) - $2350
Stage 3 Fuel (2000cc Injectors) - $2850
Weldon Fuel Pressure Regulator - +$100 Option
Rails come in Polished or Black Anodized.
You will need to specify if you have an RB25DET or RB26DETT because we have separate mounting hardware for both applications.
Each fuel rail has the option to use an 11mm Injector or 14mm Injector based on preference.
Fuel Hats have been tested and will not FIT R32 GTST and Not confirmed but claimed Not to fit R32 GTR.
Hats Fit R33 ALL, R34 ALL and S13, 14, 15.
This can handle 1000hp with ease.
LinkBack URL
About LinkBacks
