#2 no fire..
  • #2 no fire..
    alright i had a problem with my battery blowing up, i got a new one in and started the car up. i realized i was on 5 cylinders so i started unplugging packs and found that my number 2 cylinder isn't firing. i ordered 6 used packs and a brand new subcoil harness (after 18 years it was super crispy so i thought why not). i have the harness installed then today i got my packs in, i put one in and still no fire. i tried another and still no fire. does any1 know whats going on? i cleaned up the plug as it was a bit dirty as well.
    Ignitor?
    (O||O___SKYLINE___O||O)
    SERENITY NOW!!!!!!
      the problem is either your ignitor pack is toasted or the wiring between the ECU and the ignitor pack is screwed up.
      Try replacing the ignitor if you can have access to a spare one. If not you could get a scope and look at the signals in and out.
      Etienne
      1990 Nismo GtR #283
      354hp - 292 ft-lbs
      -"And I thought my girlfriend was high maintenance..." -Etienne
        or dead cylinder
          Start at square 1:
          Did the plug smell like fuel when you pulled it out?
          Brendan : Union Autoclub
          '01 Audi A4 quattro - daily
          '90 240SX Coupe - RB25
          I had a Skyline once.
            Yeah if it's fouled it won't run =/ Try replacing the plug.
            Before you do that just compression test that cylinder and see if it's worth any more time trying to diagnose.
              Here's a quick list of things to check.
              First, determine if your problem is likely to be ignition, fuel or compression. If the problem just started suddenly/recently, it is most likely ignition or fuel.
              - Let the car run for a minute, then pull the #5 plug. Is it wet with fuel? If yes, then you have an ignition or compression problem. If no, then you have a fuel problem.
              Ignition or Compression Problem:
              - With the spark plug out of the engine, place it in the coil, but place the side of the plug against a metal surface that is grounded (like the plenum or valve covers). Unbolt the CAS from the engine, but leave the wiring connected to it. Turn the ignition to the "ON" position without starting the car, and rotate the CAS to see if the plug sparks. If the plug doesn't spark, try another coil and plug you know work. If that still doesn't spark, then you will need to trace wiring from the coil to the Igniter, and the igniter to ECU to determine where the signal is getting lost. You can use an ohm meter to trace wires, but you really need a scope to test the ignition signal.
              - If the plug does spark, do a compression test with all plugs out. It should be at least 130PSI.
              Fuel:
              - If the cylinder and spark plug were dry after the first check, then you have a fuel problem. Use a scope to make sure your injector is getting a signal. Clean the injector's electrical connector, and make sure the injector ohm tests to the factory spec. If the ohm test reads infinite resistance, or if you verify that the injector is getting a signal but not firing, then it is either stuck closed, clogged, or the coil inside it is burnt out and it will have to be replaced.
              Feel free to shoot me a PM if you have questions about trouble-shooting it!
              FINAL CLEARANCE! EVERYTHING MUST GO NOW!
              The Best Brands. The Best Builds. The Best Service. The Best Prices.
              - 1.888.ZED.TUNE
                Check to see if your ECU harness is tightened fully (passenger side kick panel). Had the same problem last year, couldn't find out what was wrong for the life of me. Turned out the harness was almost completely unscrewed from the ECU. Must have been knocked one too many times, but it was a free fix
                  yea i eliminated the ignitor option as well so today is the fun wiring option, i'll keep everyone updated, i did compression check and there all within 80% of each other
                    try swapping parts with other cylinders (injector/coil/plug) . if the problem follows you just found the bad part.
                      alright so heres my problem. im still not getting fuel from number 2 and 3, all are sparking. now heres the list of things that i've done, im extremely stumped. i changed the fuel filter, checked the wiring for continuity, replaced injectors. tried another resistor pack, still no change, i dont get it :-? does it seem to be my ecu is the culprit? or would it even do that to 2 cyls if it was broke?
                        Looks like a wiring problem.
                        What I would do: get the CAS out, pull fuel pump fuse, tuen key to on, turn CAS slowly and check for injectors clicking. It's easier if you have a mechanic stethoscope.
                        If they don't click, you can swap the connectors to isolate the problem (wiring or injectors).
                        Hope that helps.
                        1990 Nismo GtR #283
                        354hp - 292 ft-lbs
