Hey guys
Well, I decided to light her up tonite, and after checking everything I could think of, it wont start. I did do a few mods since the last time I started it. Its an RB20 in an S13. I put an RB25 turbo on it and replaced all the gaskets. Never disconnected the O2 sensor.
I did put GTR injectors, and wired up some 10w10a resistors on each line before the injectors as per the sticky by Matt. I didnt have them flow tested, but I assume unfortunately that they are fine. I did go with a chipped ECU I bought from someone in the states. It was tuned by EO Performance. The ECU flashes a cool Code 55.
There is gas to the stock FPR and the Walbro is definitely pumping. I did rearrange my homemade FMIC. My AVC-R for some reason shows 0 with igniton, and only goes to about -20 mmHg when cranking. I dont recall what it used to do because I never payed attention to it.
I do hear a few clicking sounds, like relays, near the ABS actuator and windshield wiper motor on the passenger side, but I wouldnt suspect that to cause not starting.
I checked vaccum lines and didnt notice anything not connected. It was way to cold to give it a good check, even the garage was like so cold and its insulated. Any ideas?
Thanks!
Thanks!
What should the resistance be on them?
