boost controller question
  • boost controller question
    i have most everything figured out. the manual says to connect the solenoid to the wastegate and the pressure side of the turbo. my question is does it matter if the line connects right after the turbo or can it be connected after the intercooler?
    i am installing an AEM tru boost system on my rb25det and i can not find any lines coming off after the turbo, just after the IC.
    thanks for any help
    any boost line is fine. You can grab it off the manifold if you want too. I know the 20 has a bunch of lines plugged off. So you could tap it off there if you wanted.
    But you would be pulling the line from the turbo to the wastegate anyway. Why cant you just run the line from the turbo in and the line back out to the wg. You will have a boost leak if you leave it off.
      is there a stock solenoid? i have lines comeing from the wastegate and from the intake pipe that connect to a pressure valve looking thing with 2 wires coming out of it also.
        I cant say for sure on the 25. Maybe Judas or Chris could tell you.
        If its like the rb20 it would just have a line coming off the turbo side somewhere going right into the wastegate. No solenoids or anything in between. Not like the GTR's boost restrictor thingy.
          ok...i think i got it figured. there is a line that comes from the cold IC piping that goes to the wastegate. so i just put the AEM solenoid in that line?
            should be it.
            If its the line that normally goes to the wastegate then you are in the right spot. You will just pull that off the nipple to the wastegate. That line in your hand will be the line from the turbo. The nipple will need a line put on it and that is the line to your wg.
            Good luck with it.
              thanks stinky_1
                There is no stock boost solenoid, your stock boost level is controlled by a spring in your wastegate. I don't know how universal the spring is, but for more reliable boost installing a stiffer spring in your wastegate is another way to go.
