hey guys hjust wondering if a s13diff VlSD style will work in my GTS-T??? and if so what will be the other mods to get it in there??
s13 diff will it work???
Look at the bolt patterns on the diffhead ears (where the halfshaft's bolt up to diff), as that's usually where Nissan diffheads are different.
From what I understand you need the diffhead carrier (what diffhead bolts to), diffhead, halfshafts (if the bolt patterns are different on the diffhead ears). Otherwise they should bolt up.
Also look at the ratio of the diffhead, as it affects the speedo readings and speedo might need to be recalibrated. Diffhead ratio should be on the blue id plate in the engine bay.RESPONSE MONSTER
