Hi Sponsors, Im looking for a rebuild kit for my Rb25Neo turbo, or to see if it is even worth rebuilding my turbo cost wise Thanks!
Soon to be Neo6 GTS-t!!!!!! Cant wait
Out of Japan there will be nothing to offer. That turbo is definitely a disposable item.
Suggesting a turbo rebuild shop in Alberta somewhere. Plug it in Google.
Ok thanks ill check into it!
For RB25DET, rebuilt turbo is not worth the $$$ for the hp gain.
Better to buy a GT2540 turbo (bolt on) from HKS (Feastauto can help you with that). An example is Max's R33 GTS-T (Thanks to Feastauto) which has a HKS GT2540 turbo -
http://www.youtube.com/watch?v=rYa1Ux4qOwM
HKS GT2540 compared to other HKS turbo's (T3 flange) -
http://www.hks-power.co.jp/products/...urbinesho.html
Or GT3076R with internal wastegate exhaust housing (0.82 A/R exhaust housing) from Garrett that bolts onto stock exhaust manifold. Good for roughly 445hp at around 1bar (14.7psi) and full boost at 3500rpm with electronic boost controller.
ATP turbo sells these bolt on internal wastegated GT3076R turbo's for RB25DET -
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
Dumppipe flange to suit internal wastegate exhaust housing -
http://www.atpturbo.com/mm5/merchant...egory_Code=FLS
But you'll need custom oil, water feeds and custom dumppipe to suit. Also a Aftermarket ECU + retune, bigger fuel injectors, bigger lph fuelpump, Z32 AFM, Front mount intercooler to match the GT3076R turbo or HKS 2540 turbo.
What kind of issues will i have if I run that turbo if its leaking oil?
Well i think ill just buy a GT30 soon!
