I have a set of Tomei Outlet Pipes for the BNR32 RB26 available in Toronto, Canada.
The pipes were fitted to a car, then removed without using.
They are basically brand new aside from some possible small scratches due to being installed.
Retail: $737 CAD
Selling for: $625 CAD
Shipping: at cost via Canada Post
Application: BNR32 (with factory, N1, Nismo, or Arms turbos)
Payment: PayPal or EMT
Info:
Maximum Strength & Efficiency With Lost Wax!!
The stock turbine outlet pipes internal diameters are small and restrictive which raises the secondary exhaust pressure. When the secondary exhaust pressure rises it will cause power loss and lack of response with unstable boost pressure. The TOMEI outlet pipes have been specifically designed with the larger internal diameter to improve exhaust gas flow efficiency with the reduction in the secondary exhaust gas pressure. This design has been proven effective on the engine bench dyno R&D as well as in the real world environment as proven on the race tracks with our ARMS turbines.
Diameter: 68mm
LinkBack URL
About LinkBacks
