Results 1 to 3 of 3
Thread: VEX OS Giken Close Ratio and OS-88 Transmission info!
    Apr 2008
    Calgary
    294
    The OS Giken Close Ratio Gear kit is produced for those who are seeking a solution for for a stronger transmission and better results. The ratio of each OS gear set is determined through research and many actual race track tests, so that it s possible to use the performance of your highly modified engine to its full extent. Carefully selected quality materials are used, and every gear is forged for extra strength. Furthermore, metal surface processing called “hard shot peening” are given to the gears so that they can hold heavier load for reliability. OS Close Ratio Gear sets are based only on quality, not in production costs.
    Many grey-market, or JDM suppliers who attempt to sell OS Giken Gearsets do not include english instructions as we do, nor do they tell you the necessary OEM factory updated parts that are needed to have the OS Giken gearsets work perfectly.
    Below is what is available for the R32 and R33 GTR's
    - 3 Speed Close Ratio Gear Kit $2,590US (+GST, Duty, Brokerage)
    This kit is designed for the racer that requires the alternate gearing. It is recommended for low to medium powered GTR's
    - 3 Speed Close Ratio Gear Kit with 5th Gear $3,190US (+ GST, Duty, Brokerage)
    This kit is designed for the road racer that requires the shorter gearing throughout. It is recommended for low to medium powered GTR's
    -3 Speed Close Ratio Gear Kit with Reinforced input shaft $3,190US (+GST, Duty, Brokerage)
    This kit is designed for the drag racer, or street car. It is recommend for low to Hi Power GTR's. The input shaft is replaced with a stronger shaft that can handle more load and shock.
    -3 Speed Close Ratio Gear kit with 5th gear and Reinforced input shaft $3,690US (+GST, Duty, Brokerage)
    This kit is the strongest gearset you can buy that uses the factory transmission case. When paired with the OS Giken Reinforcment Center plate it can handle alot! OS Says the transmission case will fail before the gears do! This is designed for all types of racing and street cars.
    -Reinforced Center Plate $990US (+GST, Duty, Brokerage)
    This can be used with any gearset, and replaces the center section of the transmission with a billet section. This greatly prevents the actual transmission case from flexing, and therfor allows the gears to stay in full mesh even under hi power. This plate is specially coated to decrease wear
    -OS 88 6-Speed Sequential Transmission $13,290US (+GST, Duty, Brokerage)
    OS Giken has designed this sequential transmission to specifically fit the engine characteristics of Nissan's RB26 engine to allow the engine to perform to its maximum potential. To meet the incredible demands of strength and quality required, OS have used primarily forged and reinforced materials. By optimizing gear size and settings, we have increased the gear axis distance to 88mm, resulting in a 6-Speed sequential transmission able to withstand up to 1500 horsepower. In addition, our original dog linked mechanism enables accurate shift changes as well as providing positive shift feel. Each product has been hand made and thoroughly examined prior to shipment. This transmission is for RACE USE ONLY. It is not practical for street drivability.
    Standard Gear Ratio : 1st:2.609 / 2nd:1.934 / 3rd:1.521 / 4th:1.210 / 5th:1.00 / 6th:0.852
    Optional Ratio 1 : 1st:2.609 / 2nd:1.934 / 3rd:1.521 / 4th:1.210 / 5th:1.00 / 6th:0.785
    Optional Ratio 2 : 1st:2.890 / 2nd:1.981 / 3rd:1.468 / 4th:1.174 / 5th:1.00 / 6th:0.757
    Optional Ratio 3 : 1st:2.516/ 2nd:1.865 / 3rd:1.468 / 4th:1.174 / 5th:1.00 / 6th:0.822
    Requires Special OS Giken R3C or R4C Clutch Assembly $2,390US-2,640US
    -OS 88 Adjustable Fork kit $155US (+GST, Duty, Brokerage)
    Return Spring aids release fork to returned position. Adjustable push rod
    -OS 88 Transmission exclusive cross member $640US (+GST, Duty, Brokerage)
    When installed with OS 88 transmission it allows for an extra 40mm road clearance
    Prices are current at posting, but may change at any time.
    -Ryan
    ryan@VEXperformance.com
    Toll Free: 1.855.VEX.PERF Local: 403.243.1111
    Authorized Canadian Dealer / Distributor / Tuner for:
    Haltech Engine management Systems
    OS Giken
    TiAL Sport
    Garrett Turbochargers
    Tomei
    Motul
    Nismo
    Rally Armor
    COBB
    C-unit's Avatar
    Jan 2005
    Richmond, HongKong
    2,953
    how much is brokerage?
    And does the price include all the OEM parts needed to install the kit? (3 speed with reinforced shaft)
    輝く ヘタクソの星 -- 訓啦柒頭
    Apr 2008
    Calgary
    294
    Duty is apx %6
    The OEM parts needed are depending on exact year of transmission and are not included in this price. To retrofit any year of R32 transmission to OS Giken standards is apx $700 CAD from Nissan. Assuming you use the OS Giken input shaft. If you choose to use the Nissan input shaft, then you need to have the newest version
    -Ryan
    OS Giken
    TiAL Sport
    Tomei
    Motul
    Nismo
    Rally Armor
    COBB
