Haltech Engine Management Systems have been manufacturing and designing aftermarket ECU's longer then anyone. They developed one of the first aftermarket ECU's in the world in 1986. They offer top notch support, and products for nearly every level of performance.
Haltech Platinum Pro ECU's are one of the most powerful Plug-n-Play Complete Engine Management Systems for your Skylines you can buy! It offers the fastest processor Haltech makes. The software is excellent and the most user friendly around! It is completely customizable to suit your (or your tuners) needs.
Haltech does not limit who can tune your car (We Highly recommend a professional!) Your ECU's tune and settings can be Password Locked if you so choose.
Supported Cars:
Nissan Skyline R32 with RB25DET
Nissan Skyline R33 with RB25DET
Nissan Skyline GTR R32 with RB26DETT
Nissan Skyline GTR R33 with RB26DETT
Features:
Direct plug and play replacement of the OEM ECU, no rewiring necessary.
Uses the cars factory sensors
Supports R32 GT-R twin MAF sensors
Supports Sequential Injection (peak and hold) and Direct fire ignition
Windows 2000, XP, Vista compatible software
Real time programming, instant hesitation free adjustment while engine is running
Fully user definable 32 x 32 mapping
Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
Selectable on-board internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
Wideband auto tuning using user definable target AFR table
USB and CAN Communication Port
Fully Tunable Knock Detection with ability to retard timing if knock is detected.
Plug and Play with Haltech / Racepak IQ3 Dash!
Factory Outputs:
6 x Fuel Injector outputs
6 x Ignition outputs
Tacho, Boost Control, AC Clutch Relay, Idle Control
Thermo Fan, Check Engine Light, Fuel Pump (Variable Speed)
N-VCT ( Nissan Variable CAM Timing Control)
Factory Sensor Inputs:
OEM MAF sensors, Throttle Position Sensor, Oxygen sensors,
Coolant Temperature sensor, Vehicle Speed Sensor,
Air Temperature sensor.
Knock Sensors
Optional Harness Auxiliary Inputs / Outputs
2 x Analogue Voltage inputs
2 x Analogue Temperature inputs
4 x Digital pulsed outputs
These Inputs and Outputs can be configured to input / output many things, some of which are:
Inputs:
Flat Shift
NOS Enable
Fuel Pressure Sensor
External Map Sensor
Oil Pressure Sensor
Exhaust Gas Temperature Sensors
Oil Temperature Sensors
Outputs:
Aux Fuel Pump
Coolant Temperature Switch
Generic Duty Output
Functions:
Closed Loop 02 Control
Closed & Open loop Boost control
Over Boost cut (either fuel or ignition)
Rev Limited (Ignition or Fuel cut soft or hard)
Boost per gear
Correction Tables: Fuel / Ignition / Boost:
Cranking
Air Temp Target Correction
Coolant Temperature Correction
Map Correction
Zero Throttle Gear Correction
Cylinder Trim
TPS Correction
Generic Correction 1
Generic Correction 2
Gear Correction
Post Start
Air Temp Duty Correction
Post Start
Miscellaneous:
Data Logging: 448Kb of on-board data logging, Storage for approx 40 minutes at 10 logs per seconds, 6 channels of data
Max 20 channels logging capability
Tune can be password protected in software
Rugged anodized aluminum casing
PM or Email for pricing or questions
LinkBack URL
About LinkBacks
