Results 1 to 10 of 10
Thread: Rear Windshield Wiper Plug
    Dec 2011
    Mississauga
    25
    Hey All !! I just purchased a R32 Skyline 4 door and it never came with the rear wiper so on the back window I have two smalls holes there. Does anybody have a rear plug that I can plug up the two holes with? Worst comes to worst, I will just buy the rear wiper but I prefer no wiper for a cleaner look. Anybody have this item, message me back asap as I am looking to buy it asap. Thanks!
    Jun 2011
    Toronto
    1,562
    A simple fix (which is what I did) is to find the rubber stopper plugs at home depot that are the size you need and just insert them in.
    Good to go
    Because race car.
    Dec 2011
    Mississauga
    25
    Cool. Thanks! I will give that a try.
    Quote Originally Posted by MKIV View Post
    Good to go
    Jan 2011
    Victoria, BC
    126
    Or better yet lift up your trunk carpet and there is a rubber plug that covers a bolt and it fits perfectly into the hole and you already own it!
    Jun 2011
    Toronto
    1,562
    Quote Originally Posted by M-type View Post
    seal with silicone cleanly on both sides for leak proofing
    ^ make sure you do this as well!
    Because race car.
    GTRCer Murchie's Avatar
    Sep 2010
    Toronto
    181
    http://www.skylife4ever.com/2011/01/...er-delete.html
    Now you need to plug the large hole in the rear windscreen and the small nozzle hole as well. For the nozzle hole, you can use a simple nut and bolt, then glue a plastic bolt cap on top to make it look clean.As for the larger hole, I used a combination of varying sized washers, one longer nut and a bolt. Which sandwiched a couple of round rubber gaskets between the washers, and a larger plastic cap on the bolt head to give it a clean looking finish. I also used silicone gasket maker on the glass surface to separate the metal washers from the glass, that way if the metal ever rusts, the rust won't put pressure on the windscreen and cause a crack. You'll also need to be careful when tightening the hole thing together, too little torque and you'll have a water leak in the rain, but too much torque and you'll shatter the glass.
    Dec 2011
    Mississauga
    25
    For sure. Thanks!
    Dec 2011
    Mississauga
    25
    Quote Originally Posted by Silbee View Post
    Sweet! Yea, it fit perfectly.Thank u!!
    Dec 2011
    Mississauga
    25
    Much thanks!!
    Sep 2010
    Toronto
    181
    Quote Originally Posted by 4door_r32 View Post
    Much thanks!!
    Npz
  1. Replies: 5
    Last Post: 05-19-2011, 12:01 AM
  2. Plug to fill hole when removing rear wiper ?
    By MaxGTST in forum General Skyline Discussion
    Last Post: 07-29-2010, 01:27 PM
  3. WTB rear wiper motor plastic plug
    By flipridah17 in forum GTS Tech
    Last Post: 01-06-2008, 05:59 PM
  4. BNR32 windshield wiper blade size
    By derek240 in forum GT-R Tech
    Last Post: 11-24-2006, 12:39 PM
  5. WTB: Rear Wiper Motor and Wiper Arm
    By vancouverskyline in forum Parts for Sale
    Last Post: 11-17-2005, 10:17 PM
