Here is the info I have on spark plugs for the R32 and R33 with NGK:
Spark Plugs
NGK plugs are pre gapped at .8mm if there is no gap number on the end specifying otherwise, eg:
BCPR6EIX = NGK iridium heatrange 6 gap = .8mm
BCPR6EIX-11 = NGK iridium heatrange 6 gap = 1.1mm
BCPR5EIX-11 = as above but heatrange 5 (factory recommended)
PFR5A-11 = NGK recommended platinum plug for r32 rb engines.
NOTE: For the r32 and r33 engines if buying NGK you need plugs with part number starting BCP, not BK. They look the same but have a different taper. The heatrange 5 is standard, 6 is colder which may be a good idea for more boost, and the recommended gap is 1.1mm, which should be closed up for more boost, which is why .8 gap has been suggested. Its harder for a spark to jump the gap when theres more pressure in the cylinder.
You should have either BCPR5EIX or BCPR6EIX plugs if they are NGK.
Spark Plugs
