R32 Alignment Settings
This is a sticky topic.
    Stickyfied
    it was a sticky back in the old forum version... I don't get how it got lost some how
    Marc-André
    _________
    2.2L RB20 GTS-T
      which one of the three would work for my 91 gts-t rwd not 4wd?
        the one that's not 4WD
        (that would be FR)
        FYI: "Front engine Rear wheel drive"
        Marc-André
        _________
        2.2L RB20 GTS-T
          the link isnt working anyone know of another link with the specs? or will 300zx specs really work. this is for a hcr32 btw
            bump??
              Originally posted by Nismo_line View Post
              bump??
              I have the specs printed out long time ago. I'll try to find it, make a copy before Friday. And yes the 300zx specs works too.
                which one thou the 300zxtt or na , 2 seater, 4 seater
                  Could I please have the wheel alignment specs for R32 GTS-T. Also after doing hours after hours of research, what is a good setup for my hks hypermax coilovers? i have front and rear adjustable upper control arms. I can't get a concrete answer, My driving style is grip, not drift, and also I drive on bumpy Calgary roads. So nothing too aggressive.
                  Mike
                    I may be able to get you the original GTS-T Alignment Specs sometime this week. If I can, Ill get back to you.
                    Check out my YouTube Channel - HERE
                    Check out FS Motorsports - HERE
                      Thanks Farshark!
                        Here are all the alignment specs;
                        Also available are R32 GTR/R33 GTS/GTR
                        Closest on alignment block is a 240SX.. I think the Toe is the only thing that's slightly off..
                          Just get it done where they have a 'Hunter Alinement Machine'. Thats what we use and it has every GTR (R32/33/34/35), It even includes Vspec/mspec/nurb and other trims as well. Comes with diagrams built into the software and simple instructions. No way even the dumbest mechanic can screw it up
                            I smoked a median and needed to replace my whole rear subframe, after my alignment was totally buggered and the Hunter saved my tires and ball joints :S
