I noticed there are a lot of AFR and tuning questions in the forums, but no tuning guide/FAQ, so I thought I'd start one. This isn't meant to be a DIY guide, but just a thread to share tips and experience. I've had the chance to learn a lot from various tuners over the years, and I’ve helped build a fast GT-R or two, so I thought I'd share a few insights.
Disclaimer: This isn't meant to help you tune you car on your own, it's simply to give you an overview of how a car is tuned. There are many specific issues that may affect your specific setup, so talk to a qualified tuner.
Those with first-hand knowledge and experience, please feel free to add/edit/correct this information as this is mostly off the top of my head.
”It’s not running right, it needs a tune.”
I always hear people say that, but does it? Tunes don’t change. If your car is not running right, then something is wrong and you need to figure out why and fix it before tuning it. You can't tune out mechanical issues! If you think it's running rich of lean, figure out why. Which leads us to the 6Ps…
The 6Ps
[u]Proper Preparation Prevents Piss Poor Performance[u]. I’m borrowing this one from the 300ZX (Z32) world courtesy of Ash. It really applies to any turbo Nissan. (http://www.twinturbo.net/nissan/300z...ormancegt.html)
What this means is, you can't just show up at the dyno and expect to make power. Especially on an older car, you need to make sure that it's ready to be tuned. There are several steps to this.
Check and replace your plugs. I usually go with NGK Irridium XI for Zs/Skylines/Gs/Zs and even R35s. At least NGK something! Save the economy plugs for your winter beater. Make sure they are gapped correctly for the boost you want to run, and that they are the correct heat range. More boost requires a smaller than stock gap, and also a colder heat range plug. Ask if you're not sure what plug/gap to use. Change them at least every 1-2 years…I don’t care if they are long-life, old plugs will cause you to lose power after a year or 2. If your car doesn’t pull smooth and hard under boost, old/worn/wrong plugs are often the cause.
Timing. Check and set your timing to the factory spec. Note that many Nissan models require putting the car into base-timing mode before checking or setting timing because the ECU can change timing on the fly at idle. Check your service manual for how to do it properly, and for the spec (some engines are 15degrees BTDC, and others are 20). On older models, your CAS should typically be set roughly in the middle of it’s range. If it’s off to one side, either you set it wrong, or your timing belt is off a tooth.
Intake system. Turbo cars use an air-tight intake system. Or at least that’s the idea. If your car is 10-20 years old, you probably have vacuum/boost leaks. These can cause issues with everything from AFRs (Air Fuel Ratio) to laggy boost to lack of power. If you have access to compressed air, remove your air filters and pressurize your whole intake to 6PSI MAX (NO MORE). If it won’t hold 6PSI, find and fix any leaks. Replace old vacuum lines, replace loose worm-gear clamps, check your turbo and IC piping for leaks.
Filters. Air filter and fuel filter. Clean, check, replace. If you don’t know when you last changed your fuel filter, change it.
Fuel system. If you’re running more than stock boost, realize that you may need larger fuel injectors and a larger fuel pump. More air volume requires more fuel. If you don’t have enough fuel, you will run lean, which can cause excessive heat and engine damage. We’ll talk about monitoring fuel during tuning below.
Boost controllers. If you’re going for more than stock boost, get a proper dual solenoid controller. If you have a single solenoid Greddy/APEXi and want to run much over a bar, toss it in the trash and buy a dual solenoid Blitz/HKS unit. They cost $$$, but you can’t buy cheaper power than a boost controller that gives you faster boost response and holds peak boost properly without spiking.
Compression Test. If you’re going for big power, don’t bother unless you know your engine has solid compression. On turbo cars, it can be hard to tell when compression is low because the turbos keep pushing. But pushing an engine with weak compression is just going to push it over the edge.
Fuel Pressure. Turbo Nissans use a rising rate fuel pressure regulator. What this means is that for each 1psi of boost pressure, the fuel pressure also rises 1psi. You can use a 100psi fuel pressure gauge to check that fuel pressure rises under boost.
A wideband AFR sensor and gauge is required for tuning. Most dynos will have one, but if you are tuning on the street, you will need to install one since you can’t tune safely without one. Innovate widebands have proven to be the most accurate.
Trouble Codes. Check for fault codes or sensor failures. On older models, the computer only checks for a complete failure of a sensor circuit, it doesn’t check for valid information from the sensors. A lot can be wrong without the check engine light coming on. Ideally, you can use a consult program to monitor sensor readings, or use the service manual to manually check values with an ohm meter.
Turbos. If you have upgraded turbos, keep in mind that running 14.7psi/1bar on larger turbos is not the same as running 1bar on stock turbos. A larger turbo can push more air (CFM) at a given pressure than a smaller turbo can, which means when you change to larger turbos, you need to adjust your fuel system and tune to provide more fuel. A lot of people think 1bar=1bar no matter what the turbo, and they forget that it’s the airflow volume that matters, not the boost level. More air simply requires more fuel!
Tuning Overview:
When you're tuning a turbo-charged car, there are several things to be aware of. Achieving maximum power is a matter of balancing engine compression ratio, fuel octane, boost level, timing, EGTs (Exhaust Gas Temp), AFRs, etc. While you need to be conscious of how much power your engine can physically withstand, it’s just as important to understand how to prevent detonation, which can kill even the toughest engine.
Normally, fuel burns in a controlled and expected manner within your engine. But when pressure/temperature exceed a certain point, the fuel can detonate, or instantaneously explode. This can cause extreme heat and stress on internal engine parts, and can lead to pitted or broken pistons, flattened bearings, or even total engine failure. If you don’t understand how to detect detonation, do a lot of research before you start tuning.
Detecting Detonation
Bad detonation can often be detected audibly as a faint knock, tick or rattle under boost, but even inaudible detonation can do damage. Most dynos will have a detonation mic and amplifier, and there are also electronic detonation monitors you can buy. Other hints of detonation can include un-even acceleration or power (as detonation is a miss-fire), or short puffs of smoke from the exhaust under full-throttle acceleration. If you are driving the car, the easiest way to hear detonation is to boost beside a concrete wall with the window down. You will hear the sound echo off the wall.
Long story short, you never want to hear detonation, so you need to tune to prevent it, which we’ll get into below. Detonation is also the reason that many engines have low compression. If you simple turn up the boost without proper preparation and tuning, you risk engine damage.
The 6Ps
Tuning Overview:
