Need help changing bulbs.
  • Need help changing bulbs.
    So I know it may sound stupid but I cant seem to figure out how to change my headlight bulbs on my gtst. I've looked numerous times when I'm getting gas or just in the Canadian Tire parking lot. There are a couple caps that I'm sure lead to the bulb but when I unscrew the cap I cant seem to pull anything out. Does anyone have some tips on changing bulbs?
    under the boot there is a clip that holds the bulb in, just unhook the little metal clip and you can pull the bulb out.
      heres a step by step.
      1. follow the wires to the headlight.
      2. unplug the plug from the headlight.
      3. unscrew the circular plastic thing holding.
      4. pull out rubber boot using the small tab on its edge.
      5. unhook the metal clip holding the light in place.(push down then move to the side)
      6. take out the bulb
      putting it in is pretty much the same. just make sure you get it in the right way. there are shapes around the edge of the bulb to make sure they go in correctly. just match it up and you shouldnt have any problems.
      Devil R sponsored by:
      Tunerlab.jp and Popformance
      Some people try to get attention by bashing me. Go ahead you're only giving me more publicity. <3's haters
        replacement bulbs or LED bulbs can be purchased through me
          i like the subtle slip of advertisement haha, well played :P
            ahaha i agree!
            White 1990 Nissan Skyline HCR32.
            "Skyline" Is a lifestyle.
