Originally posted by tokes
View Post
Top Mount Twin Turbo Setup
Your looking at a lot of extra work to just have the look uf top mounted twins with the 2860's. The clocking of the compressor housing will be wrong. You'll have to build custom intake and charge piping as the stock stuff will be in the wrong places, and being flanged connections, makes it a little harder.
Main reasoning, room. Side benefit, temps.1998 Stagea AutechVersion 260RS
1991 GTi-R "Angry White Ghost" - FOR SALE
Ditto...Top Mount has nothing to do with performance, just looks and ease of access (but requires more custom work to initially setup).
What matters performance-wise is HOT manifold (ceramic coating =), cool compressor (good intercooling), cool exhaust dump (large down pipes).
FINAL CLEARANCE! EVERYTHING MUST GO NOW!
The Best Brands. The Best Builds. The Best Service. The Best Prices.
- 1.888.ZED.TUNE
With coating your manifolds, if they are stock cast ones, should be ok, but if you have tube ones, make sure they are OK to be coated, as coming from the Subaru world, Ive suffered loads of cracked manifolds, some times the thickness of the steel used in the pipes is too thin and causes cracking. The Tomei tubes are 2.5MM which is pretty good, since most use 2mm i think, then again you can get custom made ones too.
Anyway i think majority of the questions were answered already. Good luck with whatever route you choose
Originally posted by Kirk View PostGotta be honest here. My hmmm...pretty much only reason to top mount the turbos is for the appearance. I will only be putting GT2860R-5's in there which fit in the stock location, but hidden. I just figure if I am throwing in new turbos, let me take car of the hard to reach bits now.
As for ceramic coating, I was looking at some companies to coat my parts before they go in. I had some ceramic Kooks long tubes in my last car and loved how they held up to the tortures of time.
XS run top mount 2835r's because that is how the kit comes from hks, it's also likely the only way that they can fit.
Kirk, we have a single turbo top mount setup (manifold & downpipe) at my shop for sale; we can also get you a turbo to match it. (see my FS post for pics).
After years of hearing about banning RHD cars .. Quebec did it.. this morning. How... well, before registering a car at the SAAQ, we need to pass an inspection, these inspection centers received a paper telling that if the steering is on the wrong side, they cannot pass the inspection, so thats mean, no inspection sheet = no
THanks!
Mitch
- Toronto, Canada
Parts. Cars. Service.
GTR
MKIV
