Hey,
Been doing some thinking again... wondering all your opinions on this:
car is a 91 GTR. heres the setup on the wheels at the moment:
Rear: 18" x 9.5" SSR Type-C RS with 265/35 Bridgestone Potenza RE-01R
Front: 18" x 9" SSR Type-C RS with 235/40 Bridgestone Potenza RE-01R
Before someone jumps on it, yes the rolling diameter of the 2 front to back are within less than 1% difference, so this setup does not cause ATTESA issues.
Anyone ever fit a 265/35 on a 9" rim?... would you guys recommend it?
see, my thought is that it will be very buldged out the sides over the rim, but this might be a good thing because a little more cushion and flex in the front tires, when inflated to like 28 PSI for trackdays, might be a good thing, as it would increase the contact patch relative to the rear tires, which would help grip and control more.
From google searches the most common answer is it depends on brand of tire, but it has been done often. I just wonder specifically with the AWD and the GTR setup, how do you figure it will behave with 4 tires at 265/35 but the rims being different 9.0" Vs. 9.5" rear.... follow?
