1/4" BSPT Male to 1/4" NPT Female / Oil temp question
  • 1/4" BSPT Male to 1/4" NPT Female / Oil temp question
    1/4" BSPT Male to 1/4" NPT Female anywhere to get this fitting locally other then from autometer accessory section?
    Also does the factory ECU use the factory oil temp sender? I'm thinking of not having this plumbed in.
    Taylor
    Factory has a pressure sender not a temperature. The ECU does not read it; if I'm not mistaken only the dash uses it.
    Go to a local hydraulic shop they may be able to help you. BSPT threaded items can be a pain to find though.
      RB26DETT has both pressure and temp factory. Looking at the FSM I don't see anything about oil temp going to it the ECCS. Should be good to go running without it.
      Ya I always hate the BSPT items. Autometer sells them but just incase lordco doesn't have them in stock I'll need another option.
        important read
