ya but the problem is how do you get the bolt to thread into the new holes? they need something to thread into on the inside of the wing
Fitment issues - cunits carbon fibre hood from group buy
These parts are not JDM, they are Chinese made knock offs if you check the original post. JDM is still the good stuff!Originally posted by GTRADDICT View PostIt's crazy how much JDM stuff is crap... Craftsmanship has gone downhill. Everyone wants a quick buck.RightDrive Inc. Parts Manager
Just make sure your hole is a fraction smaller than the outside edges of the screw and it will fit snug.Originally posted by Nismo_line View Postya but the problem is how do you get the bolt to thread into the new holes? they need something to thread into on the inside of the wingOriginally posted by Paradis^^ hows not being rich going? ...haters be hatin
I had OMP carbon fibre seats in my old car and I actually had to drill out holes for the seat mounts that didnt line up exact...the carbon was actually thick enough that I could use a tap on the hole and get realy good threads....If you make the 4 original holes and tap them ( if you can ) it may be strong enough.gtr garage queen...anybody seen my wallet?
Personally, if you mod the wing... make sure it's good and solid. Because you don't want the wing to break off like someone said earlier... It's a gamble03 lancer dead
68 gmc w/355 cid rice killer
05 chevy silverado L33
2010 crv Wife's ride
1987 Harley Softail custom
I'm wondering if the wing is hollow all the way through , if it is i might be able to run threaded steel rods through the wing and attach the wing either side with lock nuts. I went back to have a thorough look after i cooled off and the wing is about 8mm norrower across it's width than the standard factory wing so i might be able to make up some 2mm aluminum fillets to go between the endcaps and the wing body to improve its structural integrity at the ends.
Having said that the carbon wing weighs about as much as the factory wing so it might have a ton of GRP inside it which would make running the threaded rods through it somewhat hard.
Im gonna sleep on it for a while and mull it over. If I do decide to do this ill post details of it in my build thread.
and if you do get it to work you will like it that much more. Good luck
