License plate offset - left or right - and where to get
  • License plate offset - left or right - and where to get
    has anyone installed their plate offset from center for airflow purposes ???
    seems to make sense to mount on right side (for skylines) to allow better airflow to intake...
    and where to get such a thing ??
    i love alberta rear plates only. im pretty sure they are just custom mounting bracket shouldnt be that hard to create one i havent seen a kit
      i found old aluminum L brackets from back in the day for intakes...just go to homedepot or cdntire for two L brackets and use a wide selftap screws that went on the bumper...then ur 10mm nut and bolt for the plate
      Toy: BNR32
      DD: R50
        should cost u under ten bux
        Toy: BNR32
        DD: R50
          Thats hot, just sayin.
            I used a single piece of 1/2"x1/8" -ish steel strapping. Found a couple unused holes in the framerail area and avoided putting holes in the bumper by routing the bar through an air inlet with creative bending.
            Food for thought.
              I really wanted to do this as well but my oil cooler is located on the right. fml
              1992 R32 GTS-T Type M
                Me too, I'm not going to bother relocating the plate. I'll just remove it when I really need to maximize my intercooling. Just carry a nut driver around with you, takes all of 30 seconds.
                If a cop wants to be an a$$hole he could tell you that the plate mounted on the right and pointed away from oncoming traffic is in some way tring to hide it from law enforcement. Just another thing he (bitch) could pic on in a traffic stop/roadblock. Mounting the plate like that can also give you an advantage in avoiding Lazer radar, some cops might know that.
                Jon .
                  I've thought about relocating to the right side. I even have fog light holes in my bumper that would be perfect mounting holes. What do you hide the holes in the center with? they are squares with threads in the middle, about 1" by 1" and would look bad if left untouched. I was thinking of a novelty plate like this thats skinny.
                  I would never put a GTR badge on a GTS, I'd make the plate relevant to my car.
                  89 Nissan Skyline GTS-t sports limited sedan
                  4 door love.
                    on a side note : I was thinking about trimming the top and bottom of my plate so when mounted in the stock center location it would not cause any aerodynamic obstructions for the intercooler/rad.
                    Does anyone know of any legal ramifications that would come up by doing this fantastic MOD..???
                    thx
                      double sided tape, wont ruin the bumper with holes, and that **** holds everything..make sure its 3M it works wodners, I SWEAR!!!
                        What about zap straps? lol Mines zap strapped onto the driver side of my bumper in the same location as markc32
                          I <3 Alberta
                          RB25 Powered RWD GT-R
                            thx
                            Depends on your province. Check the regulations or just call your local PD and they'll tell you.
                              I know in Ontario you can't cut your plate but where you are give it a try. If you get pulled for it whatever go pay the 15$ and get new plates. I personally went with the cusco relocation plate. Cost me 60$ but it mounts great and will look awesome. Definitely mounting the plate off to the side.
