could some one help me out. im really interested in stroking my RB26DETT to an RB30DETT and i was wondering if its really worth it?, what the plus and minuses are about it. and if it is worth it could you list some general things; eg, pricing and what i need to get. thanks a lot.
Rb30dett
Not much of a help.
But all I know is it's expensive as hell! I think a lot of people try to locate a RB30 block and go from there. I heard for the set up to work you need to dump stacks and stacks of cash to make it perform well. I have never looked in to this. Just read about it here and there.
edit: saw the above post after I postedLast edited by bellis_GTR; 11-02-2011, 10:42 PM.Heart rate 160, I'm goin 260, RB26 run me past you in a jiffy
Yea.... If you go with a gt45r you'd be more or less around 1000whp. As super said, the gt35r will net you 500whp quite easily.Originally posted by Lefty View Postso whats a good set up for me if i was looking to make around 500-550hp in terms of turbos, injectors and etc... i was think of going with the GT45R and 750cc injectors with dual wellbro 255 pumps.
as for the fueling, 750-800cc injectors will be fine, just make sure their flow matched. The fuel pumps, i'd go with a single bosch 044 or an aeromotive 340 stealth. Walbro may seem like a great deal but at 13.5v the flow isn't what they say it is. http://realstreetperformance.com/sto...on-test-5.html
reason I prefer a single pump is it's useless to run two pumps if one can do the job with enough safety margin. a dual pump is more dangerous than a single pump in the fact that if one fails it could run lean for a good amount of time before you realize it, if a single pump fails it's just like running out of fuel (a lot less chance of damaging the engine)The GT-R doesn't run on gas, but on the tears of children.
An oem rb30 bottom end with an oem rb25/26 head will get you the missing low end power. There is a video of the RIPPS guys who built a guy a drift car with that set up. Stock top and bottom and the guy had been beating on it for two seasons. Sure you can spend a **** ton to build these motors. Out of the box they are good, just upgrade the water and oil pumps along with gaskets and your setR33 GTST RB25DET series 1
