Hks v cam system?
  • Hks v cam system?
    Hi, has anyone ever used the HKS V CAM System?
    Im pretty sure its like adding variable valve timing to our rb26 engine. this i think would be really cool, it would help with fuel economy and also with performance.but it seems to be really rare because i never really heard of anyone actually trying it out.
    has anyone every tried it out? and would it be worth it? thanks...
    and heres a link,
    Purchase aftermarket performance parts direct from Japan including Apexi, HKS, Greddy, Nismo, Blitz, Spoon, TRD and other JDM brands at wholesale prices
    I have one for sale!!! not the step 1 or 2 but the pro.
    I was going to use it on my car and did some research before and I hope this help. (maining on the pro version)
    - it helps gainning your low - mid range power (especially if you have low CR with long duration cams and running twin GT-RS or single T04Z.
    - it requires a high volum oil pump, high strength valve springs and low comp piston to use.
    I've got a ride on my friend's car who the vcam pro was originally installed. It is running a HKS 2.8L kit with twin HKS GT-RS. With the Vcam, there are more usable torque in the lower rpm range which helps alot on daily driven. I would say the turbo lag on the car is less than a stock GTR. You won't have to down shift the car as much to keep on the power band.
    Feel free to PM me if you have more questions!
      thanks for the info. i apreciate it. if i had the cash i would definitely buy it
        lol by that you mean if you had 10+k not many of us do.
          This is on a RB26 with Vcam, etc -
          This R32GTR has 2.6 liter 86.5mm piston, conrod, stock crank, HKS v-cam step1, 264 ex cam, HKS 2530kai turbo, and F-con V for engine managem...
          Note the RB26 has alot of torque.
          This is RB26 with Vcam vs RB28 -
          Many people requested compare graph for HKS V- cam and the others. Compare at1.2 bar of boost. Two graph are comparisons from:RB26 with HKS ...
            any body every see this on an N/A set up?
            im really asking Skym with your endless abbout of youtube knowledge
              see bmw m50 engines for inline 6 variable cam timing vs without. they were offered with and without vanos.
              oh hai!
                Seems like a great feature and even sportable for a daily driver since it improves MPG?
                1989 R32 GTS-t (Sold)
                  Spending 6-10 thousand dollars on something had better produce some unreal MPG gains to justify the cost.
                  1990 Skyline GT-R - Jet Silver Metallic
                  It'll run someday
                    $4500.
                    and the whole purpose of the vcam is not to increase ur mpg, it's to gain low end power. Who cares about mpg if you are running 6-800whp???
                      High HP cars and fuel economy are not related. They arent even friends. They evil eye each other in the playground and live amongst each other.
                      I've said it before on this forum.... You can't expect a hooker to be a house wife.
                      R33 GTST RB25DET series 1
                        That....you never know...
                          If shes a hooker, you're paying her alot for the hour regardless of what she does. You could technically bang her than make her go make you a sandwich and clean your horse until you run out of cash. Albeit not cheap but neither are the V max cams.
                          Double track drift, yo.
                          (o▫o sκylιnε o▫o)
                            Originally posted by C-unit View Post
                            $4500.
                            .....+1
                              There is the point to be made that, if set up properly it will give you better fuel economy. i mean yes fuel economy is a relative term when making up too 800hp. but even if you dont want it on say for city driving, just switch it off and it returns to your "default set up"
                              this is what the kit comes with,
                              what im wondering is what other supporting mods are required with this and what mods arnt compatable, it seems if you were to shell out that amount of money you have to really plan around it.
                              Its not just a car, Its a Life style
