hi folks, im slowing gathering parts to build on my stock top and bottom end r32 gtr vspec...
this is my first skyline, however ive done a fair amount of reading on these cars before purchasing, so hopefully my queries are not too annoying!
now i already have some nismo afms, powerFC, sard 700ccs bought and ready to go on.
oil cooler, filters, hardpipes, teins, clutch, exhaust, boost controller all covered also.
im looking for something in the 400-420whp area, so 500crank hp. but decent spool up and not a turbo having to run at its max to get there. ideally something that can reach that level at 1.1-1.2bar with potential for more.
i have plans for a couple of track days a year, odd 1/4 event, but 95% will be road use.
turbo;
i had in mind some 2860-5 to get the power up there with not much boost needed?? from what ive found, these seem like quality turbos to go for in the 450-650hp range? minimal lag, but good top end, cheap-ish, easy to rebuild, wildly and easily available?
what about the Nismo RS580 street turbo kit?? need too much boost to reach my goal? good to have something rare, but are the -5s really the way forward? i had considered the -7s, (similar to GTSS?), but seems to reach 500crank gona need 1.4+bar? im not sure my stock motor would like these sort of pressures??
servicing;
for reliability, i thought its a good idea to get the cambelt swapped over, is it werth while doing this on such a low mileage example (29k miles)? i thought about cams and cam gears while the belt is off, but seems over the top when i have low power (for a rb26) in mind?? plus im not looking to spend like crazy!! nissan belt ok?
i have on the cards 10w50 titan PRO S oil, lightweight shockproof oil, not sure on diff and transfer oils??
cooling;
have a radiator upgrade on the cards, have seen a few makes around, ebay ones, koyo, mishamoto (the later 2 look the same as the ebay ones but cost more!) and of course the japanese makes. are the high priced rads really werth while??
what sort of sizes should i be looking at? 40mm? 50mm? 60mm?? i still would like to keep stock fans and shroud.
i heard theres 2 different sized temp sensors on the R32 GTR, mines a may 93, is this a 10 or 15mm sensor? some rad options state different sizes.
handling;
i also have on the cards the full driftworks hicas removal kit, as hear hicas isnt ideal for track and would guess fast road use??
whats the deal with the hicas light on the dash? do i need to remove any computers/ecus related to hicas?
suitable steering wheel boss to get so i can run a nardi wheel with no hicas?
fueling;
what pumps are good these days for this level of power, mainly for easy of install?? nismo? DW? 044?
ive heard its best to directly wire the pump to the battery?
i cant imagine FPR or fuel rail upgrade is needed at this level of tune?
anything else to consider?
am trying to keep things as simple, uncomplicated, reliable as possible...(and preferably not spend a huge amount, especially on parts that are really not needed for this level of tune).
i have no plans to pull the motor and go for the tomei oil pump and forge quite yet!!
am hoping seeing as its a 93 that any oilling issues would be kept at bay.
cheers
jim
turbo;
servicing;
cooling;
handling;
fueling;
cheers
jim
