K so I finally decided to dump the gtst after a year and get a gtr. The car is dynoed 460 to the wheels but the turbo hits boost at like 6000 rpm and before you know it its smashing the rev limiter. Is there any way to reduce the lag at all? It has a power fc with the commander but im sure these turbos are just overkill. Ill post a pic of the engine and list of mods the car has. Any help is great thanks. PS dont get a triple plate clutch if you daily drive your car...lol
ENGINE:
Wiseco low compression pistons
R33 polished and balanced Crank, rods and bearings
R34 Water pump
Greddy Intake plenum
Greddy adjustable cam gears
Greddy 264 deg intake cams
Greddy 272 deg exhaust cams
Greddy 1.2mm head gasket
Splitfire coilpacks
Risky valve springs
Greddy TD05-18G twin top mount turbo kit
Custom intercooler piping
Greddy external wastegate
Greddy Airinx intakes
4in custom exhaust system with hi flo cat
OS giken triple plate clutch
Radiator with dual electric fans
Trust(Greddy) 4 layer intercooler with piping
Greddy Oil cooler
FUEL SYSTEM
Greddy Fuel rail
Nismo 550 CC injectors
Nismo fuel pump
Sard fuel pressure regulator
ELECTRONICS
Apexi Power FC stand alone engine mgmt with commander
Greddy Full Auto Turbo timer
Greddy Profec type S boost controller
2 Greddy H20 warning gauges
Greddy Fuel pressure warning gauge
Greddy boost pressure warning gauge
Greddy Oil pressure warning gauge
ENGINE:
R34 Water pump
Splitfire coilpacks
Risky valve springs
Greddy Oil cooler
FUEL SYSTEM
Greddy Fuel rail
Nismo fuel pump
ELECTRONICS
