Bolt listing for rb26 motor
  • Bolt listing for rb26 motor
    Hi Guys
    I'm trying to find a list of all the fasteners on the RB26 engine so that i can assemble a set from fastenal.
    I would like to convert most of the to hex cap head screws if possible so was looking for a listing to provide sizes , thread pitches etc.
    Bolts for the following as an example :-
    oil pan , water pump , cam wheels , cam wheel cover , heberal bracketry (ancillary mounting and engine mounts)
    DOnt think anyone has ever assembled a list because i cant find it ...
    This is going to be quite the task assembling the list but would be a great resource when completed.
      I will be needing this over the winter as well...I have a box of essentially every bolt from an RB26...a single box, nothing marked. im rattled. (came with car!)
        Damn I should of made a list of all the new ones I got well I was putting all together.
          ok i have done some research and have the waterpump sizes ... if anyone else knows others lets post them up and ill compile a complete list .
          water pump :-
          Water pump (still need underhead lengths)
          M6 1 bolt x1
          M8 1.25 bolt x6
          M10 1.5 bolt(short) x2
          oil pan bolts (still need thread pitch values)
          M6 bolt (16mm underhead) x7
          M6 bolt (30mm underhead) x2
          M10 bolt (30mm underhead) x13
          M10 bolt (50mm underhead) x1
          M10 nut
          internal oil pickup (need underhead lengths and pitch values)
          M6 bolt x1
          M8 bolt x2
          timing belt cover (rear plate behind cam wheels) , (need underhead lengths and pitch values)
          M6 bolt x1
          M8 bolt x1
            Edit: fsm states bolt sizes and location. Not the length or thread pitch.
