yes alignment would be strongly recommended. i mean you could so only rear. but that adjust your toe, and probly the most significant alignment part that can wear out your tires quickest if not adjusted properly!!!!
i was going to get the kit also, the DW, but its so damn expensive i just got a s13 non-hicas rear subframe and swaped all my parts into it and just got some s13 rear toe arms from Megan, which are like 120$ and everything is pimp... and the subframe cost me 64$. just more work to drop subframe and stuff but its not that bad to be honest. could be all done in 1 evening.
Buy the driftworks kit and support product innovation. I personally have the driftworks kit and with a few minor adjustments it goes together just fine. the old bushings are a pain but not impossible. Driftworks created the product so pay the few extra $ and support them vs the knock off ams kit where quality is questionable (cough brake pads that everyone loves so much). you will need an alignment to be proper
just the local pick and pull. i know some pay 80, 120, ive heard some pay 200..... but it was 64$ with tax lol. pretty sick. i just removed all the arms that were left on it, the stock arms that i dont need and make it cheaper since i dont need them. but yeah if you just want a adjustable rear end.... why not. save yourself some money thats for sure. and if you do get a new subframe you can change the bushings before you put it in... like since its out you can work on it before you swap it up. thats what i am doing with mine. i got new subframe, toe, camber, traction, diff, bushings. so when i put it in, it will all be new. something to think about.
