Got round to returning the car to a recirc setup and while the bumper was off thought I'd pressure test the dump valves.
Just wanted to confirm I'm testing them correctly, basically hooked up the same pressure source to the top take offs and the main pipe itself. I assume like how it operates as stock?
It was leaking slightly at the valve (I think the extra spring tension not quite holding it shut). Decided to clean as best as I could and removed them from the pipe, reinstalled. Now it's leaking from the gaskets as well, :-/.
I'm assuming dump valves should not be leaking at any point if equal pressure is applied to the top and main pipe?
I've reinstalled as I've no choice if I want to use the car, and I can't notice any ill effects, but any leak is a bad leak, wish I hadn't bothered testing em.
Where can I get these 2 dump valve gaskets?
Anyone confirm I was doing the test correctly?
Cheers
Jim
Cheers
Jim
