need opinions please!
    Did you measure the core of intercooler???? 4 inch thick doesn't tell us much (need height, length of core). If can tell us that, can work backwards via formula and give hp rating for core.
    There was a high hp GTR in the states that lost alot of hp due to incorrectly sized intercooler. But if core is too big, engine can have more mid to topend at loss of bottomend. Increasing capacity is one way to help solve the bottomend problem, but sizing intercooler correctly is usually cheaper, easier.
    Also camtiming, cam specs (264 duration intake should give more mid to topend and 270 duration exhaust should give more topend, depending on how it's set with camgears) could be another cause (can't see camgears enough in photo to see how it's adjusted).
    This link shows cam gear adjustment for intake camgear (compare to intake camgear on your car) -
    If bolt is on right side of slot on intake cam, then you'll probably have an answer as to why it's laggy (probably more than one thing is incorrect).
    It's best to correctly degree your cams -
