Nissan Fast 2010
    Works perfect, thanks.
    Not sure if the grey white color is unbearable for anybody else but the asterix in the numpad changes to a few other color options.
    92 BNR32
    92 RNN14 12.92 @ 105mph (SOLD)
    86 Sierra Cosworth RS (clone)
      Originally posted by cooke24 View Post
      Try running it as an admin. I got this from skyline Australia and lots of them have it working
      how do you run as admin?? i cant figure out how to brows part numbers, is it only possible with a vin? if i wanted to say look up a part number for a 300zx, im thinking i have to select one of the models from the cd?? when i click it and all the models pop up its all japanese
      - Adam
        Find Nissan fast exe program and right click, properties, run as admin.
        It's tricky to navigate, but with no vin you have to click the cd button then browse look for z32
        It's hard to explain
          ok a couple questions, when you finally find a diagram and are able to click on the numbers, how do you get the actual part number? im guessing the number you can click on is the second half of the full part number???
          the only way ive been able to find diagrams is to enter r32 as model number, then going to SEC index and scrolling down, and picking something sometimes works out. theyre not in any order at all though so its a pain to find anything. is there a better way to search??
          ive found a break down of the front brake system, so i can get the pad retainers i need.
          i just cant figure out what the part number would actually be.. its circled in red
          - Adam
            When browsing models without the vin, type the model, ie R32, Z32, ect. in the box beside model series. This is a bit of a pain when retrieving part numbers cause you will bring up anything for R32's not just GT-R and using BNR32 wont work. Must be 3 digits only. VIN is always the best method.
            Once you have a model or vin entered, click the general index box, hold you mouse over it to see the description, its the one with four squares and shapes inside the squares. That will typically bring up four areas to select. Once you select one it will bring you to the sub category pages, remember to use the black arrows at the top to see all the selections.
            Once you have found a sub group and you have highlighted the part you require by left clicking, you then click the small red book to retrieve the part numbers on the fast window. (right click to de-select the parts)
            Most of the time Nissan used the same first five digits to identify their parts, regardless of model. 14411 is turbos,12200 is crankshafts then adding the model specific code, like 12200-05U00 will get you a RB26dett crankshaft. Now they have revised this part to 12200-05U03 due to improvements and fast will automatically provide the most current version. If you get handy with your Nissan group numbers you can shortcut right to your subsection by entering the first 3 numbers in the part code box or enter all five and click the red book to go straight to the part number.
            92 BNR32
              As you can see on the bottom of that screen you have selected 4 hardware kits if you click the exit button( guy leaving door)
              Brings u back to main screen then select the hardware kit, click alt parts no button I think it's called
                How do you guys browse the R32? My Nissan FAST 2010 A1,A2,A3,B1,B2 disks don't have the BNR32.
                  it should my friend
                    Thus still works
                      Works great even on Windows 7 64-bit. Yeah! Going to try Windows 8.1 later.
                      Thanks a bunch.
                        Thanks for providing the download!
                        Install seemed to work fine on Windows 8, however now as I am trying to look up my vin it is saying "model series cannot be found for this vin number". And if I search model it just says "invalid model".
                        Any ideas?
