Hey everyone! I was wondering if I could get your opinions on installing a fuel pressure gauge as I want to make sure I'm doing it right. I have an electronic fuel pressure gauge and was going to install te sender in between the fuel filter and fuel rail as that's what people said when I researched it. I called a shop and they said it was fine to do this, I used a t fitting with barbed ends, just using rubber lines and p clamps. Now would this be safe under higher boost? I just want to make sure as I see myself running more power later on, right now I'm at 15 psi. The reason for this is I haven't bought an afpr yet. Which leads me to one other question, the fpr is leaking air does anyone believe it can be fixed with jb weld? Its leaking just around the circular part of the fpr!
Thanks for your help!
Aj
Aj
