Hey I have a 1990 Skyline GT-R, with a engine swap for a "fresher" RB26DETT. Let me start off by saying that Takeda Racing did the install, and supplied the engine. Everything else around the engine was pre existing. It looks like this car has been bagged on pretty hard. There are signs of a pre existing roll cage "removed before I bought it" and there are oil leaks coming from the oil relocation kit. Injector 1 and 5 are leaking pretty bad, and the bloody 4WD doesn't work which really pisses me off, apparently Koju at Takeda Racing said he could not find the problem, and that it wasn't the fuse which I checked later as well and it's fine. So I wen't to RacingGreed in Burquitlam to get the car checked out, and they put a Nistune in the car which they tuned to 17 PSI on stock pretty much everything. Needless to say I drove around the corner, and I blew a turbo... So I bought a used turbo and had them install it. I set the boost to .9 bar and when I get up to .9 it starts sputtering and bounces off of .9 bar. So I am wondering what I can do to fix that? There is a bit of shaft play in the used turbo as well. I am not sure what the original turbo condition is though either.
Apparently the original turbo's were taken to Turbonetics to get checked out when i first bought the car, and they said they were fine! So I feel I'm getting jerked around by both shops, and I'm just wondering what I should do about everything ha ha ha. The 4WD, the sputtering, the gas leaks, the oil leaks! lmao This car needs a lot of work there is so much wiring in places that it shouldn't be.. Someone made a mess of this car. I wan't to nurse her back to health any suggestions.
