ABS brake line , thread pitch?
  • ABS brake line , thread pitch?
    I'm currently removing my abs and I need to know the thread pitch for the the brake line end fittings, if anyone could help ?
    Thank you
    pretty sure its M10x1
      how sure are you?
        you can cut the tubing and save the flare nut fittings, they are good to keep in case you need a repair one off a caliper or something
          they arent m10x1 for the tube nuts that go into the abs pump and master cylinder, ill measure the ones i have off a car in the shop and ill let you know, they should be metric tube nuts for 4.75mm line, you can use 3/16 line with the metric tube nut to make new lines
            yea thanks gtr_Mike If you can do that I'd appreciate it!
              Did anyone find out what the thread pitch of these are? i am interested in knowing as well.
                M10x1.0 is the thread pitch steve
                  Thank you for letting me know, could you post a picture when you are finnished so we can see how you did it.
                    for sure i'm just trying to find my last fitting, a 3 way union (m10x1.0) to split the two front lines.I can't find that fitting anywhere!
                      If you've got a Bosche hydraulics store nearby, give 'em a call.
                      Dan
                      The Beaumont Connection
                        Don't think we have a bosche store here but we do have several hydraulic stores, would they carry that kind of stuff?
