I am planning to put together an RB23DET.
No, i do not want an RB25 even though its more cost effective, the head flows better and will achieve greater hp for the price.
No, i do not want an RB26, i'm not interested in dealing with transmission/driveshaft swaps.. broken halfshafts or LSD failures at the track..
23 is simple - on paper.
- RB20DET Block
- RB20DET Head - with various porting to match the new flow of the motor
- RB26DETT Crank - Balanced/blueprinted and machined to match the RB20DET block
- RB26DETT Rods - stock, ideally have them shot peened if the price is good or go forged
- 4AGZE Pistons - 81 mil (Stock is 78mil)
Extras;
N1 oil pump - Increased oil flow? Or is RB20 pump sufficient?
N1 water pump - Increase water supply to sufficiently cool cylinders? Or stock sufficient?
As it is now;
- I have an RB20 block in good form - needs to be bored to 81 mil
- I have an RB20 head - needs to be ported (i'll be doing the porting over the winter) and decked which, i cant do.
- Mitch is kindly donating RB26 crank - needs to be balanced/blueprinted/collar pressed
- Mitch is also kindly donating Rb26 rods - need to fit a bronze guide to fit the 1mm different wrist pins on the 4agze pistons
- Need to purchase ACL main bearings
- Need to also purchase a gasket kit/top and bottom end
- Need to purchase cams - Tomei Poncams on the RB20 Hydraulic lifters (not going solid)
- Also need Tomei Valve springs
All tuning via Nistune..
Can be done for about 2000$..
Thoughts?
- RB20DET Block
Extras;
As it is now;
Thoughts?
