i have a gts4 which has been sitting for awhile,while TRYING!! to drive in some snowif noticed! the attesa system is not working, the 4wd light is off, and torque meter shows torque to front but definetly no power to front wheels? the engine is a r33 rb25 attesa engine and i have an aem ems, any ideas of what to start looking at first would be appreciated. when i had the rb20 in it everything worked fine?
awd not working
That's odd. If the Atessa doesn't see an issue (unless your AWD light is burned out), there shouldn't be one, especially if your torque gauge reads fluctuations. Have you checked out if there's a code on the Atessa unit in the boot? The R32 Atessa is quite fishtail happy in rain, ice and snow. Is there a chance you just think it's not working though it is?
Fluid issues would fault on pressure fail, fuse/power problem would not show any torque up front and an AWD light/code in the boot.Last edited by NismoS-tune; 02-18-2011, 09:49 PM.Black 1991 GTR. Serious garage stand mantle/parts car.
fluids good, light not burnt out, thanks for all the input, it has a custom torque splitter switch and i can turn up torque to front ,so i'll check some wiring, but your comments about me just thinking its not working because of the rear slippage in snow might be closer to the solution, i was moving it out of my shop were its stored and the tires are definetely not for winter use!!!
