i have a r32 with a rb25det swap, just bought it and new to the import thing. if i have over 5 psi of boost it starts bogging really bad and it also will not rev past 5000-5500 rpm. i changed the spark plugs and gapped them to 1.1 mm, changed the blowoff valve and vented it to atmosphere.
cant boost over 5psi without terrible bogging...help please
have you ever messed around with intake manifold or ic piping? i had a torn plenum/intake manifold gasket and had the same symptom you mentioned above. while the engines is running, start from intake and work your way back feeling for leaks.- Adam
Engine can start reving up and down (o2 sensor causing this) when there's a intake airleak on intake manifold to head joint, miss at idle.
Bog can mean knock maps which can pull ignition timing to 0 degrees with foot to floor, dump more fuel in, drop boost level, etc. The safety revlimiter is set at around 5000rpm. Faulty knock sensor, knock, speedo at 0km/h are few that could cause the safety revlimiter to engage. I agree about trying to gap sparkplugs, use correct heatrange. Try this first to see if it fixes the problem. I think it should be PFR7A for R33 RB25DET (factory is PFR6A) with 0.8mm gap.Last edited by Skym; 04-02-2011, 02:56 AM.RESPONSE MONSTER
Everyone gaps differently. I used 1mm on OEM everything, then went to .8with 300hp now I use 1.1mm gap but would suggest .8mm if you have stock coils or no amplifier. Sounds like a plug issue. Have you done a compression test which doing plugs? curious.No build thread.
1991 nissan
El terror
