Boost Controller question
  • FarShark
    replied
    Do you have a voltmeter/ammeter?
    This is a bit crude, but it will help you determine which one to use, use at your own risk.
    1. Hook the negative terminal of the meter to ground
    2. Hook the positive terminal to a needle/pin and it through the wire.
    3. Rev and see what the voltage range is
    4. Repeat 1-3 for the other wire.
    The voltage range will help you determine which one is the actual "Throttle Position" which is what you need.
    Best wait until someone who has installed this to respond.
    I had a similar issue with my HKS turbo timer that required "RPM" and I wasn't getting the ideal signal because I used the 7th WIRE not the wire in the 7th POSITION.
    Hope this helps!
  • ChuckNorris
    replied
    Sorry should have been more clear! haha 93 R32 GTR
  • RABBIT
    replied
    Originally posted by ChuckNorris View Post
    The stock one
    Ok... what car do you have that uses said "stock" ecu?
    Sent from my HTC Magic using Tapatalk
  • ChuckNorris
    replied
    The stock one
  • RABBIT
    replied
    What ecu?
  • ChuckNorris
    replied
    Nobody can help me out with this? i really don't wanna make the wrong choice!
  • ChuckNorris
    replied
    Thanks guys, Yeah i had a look at the pin out a few times and dont wanna just guess. hopefully someone knows! haha
  • Nismo_line
    replied
    unless frankiman changed his the evc-s doesnt need to be hooked up to the throttle signal i read my manual(i have the hks evc-s) and didnt see anywhere that you need to hook up to the throttle signal
  • archaeic_bloke
    replied
    I see what u mean, #38, or #56?... im not sure either, hopefully frankiman can confirm because he just installed an HKS in his car
    Usually they want the TPS (Throttle Position Sensor) because on boost controllers with advanced settings (like AVCr for sure) I'm not sure if urs has it? but it must if it takes the TPS readin... anyways on good controllers you can program it to give boost based on throttle position... heres the pin out:
  • ChuckNorris
    started a topic Boost Controller question
    I have a HKS EVC 6, so my question is that with the wiring it asks for the throttle Input Signal. So on the ECU pin diagram it dose not clearly say that. Im wondering which one it would be then? The Throttle sensor output signal? or Throttle opening output? Possibly a different one?
    thanks!
