Quality Rubber Fuel Hose
  • Quality Rubber Fuel Hose
    I redid a couple of my rubber fuel lines last year when i changed my Fuel filter. Anyways, after only a year max they are already starting to crack. I used Fuel Injection hose from NAPA. I now have to replace them again and i want this to be the last time.
    So, Is there any high quality Fuel Injection Hose that wont crack after a year? Is there any ratings i should look for? And where would I find "quality" hose?
    Sorry, This sounds like im using Vac hose or washer hose, but Im not. Its these stupid things that get me irritated. This should not be an issue, NAPA if your listening.
    OEM the only way to go from what ive read on here. its expensive but they are the only ones that seem to last 20 years
      I went stainless Earls. I have some left over. Perfect lengths for anyone doing a twin entry rail and FPR.
      No build thread.
      1991 nissan
      El terror
        I replaced my dad's BMW with fuel injection hoses from crap tire some years ago and they are still holding, I'm pretty sure they were made by Goodyear as labelled on the side of the hose.
          Hmm. Ill have to go to Can Tire in the morn to see what they stock. Ill probably see what Nissan has if I cant find quality hose. But I think Goodyear would be crack free after a couple years.
            Checked local Can Tire. Nope, generic Fuel Line Only.
            Off i go to Nissan for hose at $1.50 an inch.
              That's correct, the line was in some generic green colour package but the hose itself has Goodyear stamped on it. You can also check with the local industrial hose suppliers like Greenline or go aftermarket like Bruizer said.
                AHHHH. Ill have to go and get them to pull some out of the box. I asked the counter guy and he said its not goodyear, Ill have to look for myself to make sure.
                  I got the one's off the racks in those plastic packages labeled high pressure fuel injector hoses in relatively short length (one or two foot at the most?). Not all hoses have the Goodyear stamps as I still remembered, only that one i picked up and maybe two or three other packages? They might also switched supplier since this is quite a while back.
                    Checked Can tire. Fail.
                    Went to St Catherines Nissan. Fail. Said they use hose from part suppliers like NAPA/PartsSource etc.
                    Search continues, prob have to buy online.
