hello, so i recently installed an AEM UEGO sensor *following instructions* on my RB20. i took it for a rip after it was good and warm and it seems to be leaning out to around 15.5 and upwards to where at full boost it just shows bars (unreadable). at the same time my EGT/catalytic converter sensor light shows up. i want to be running rich but it seems as if i am leaning out. below are the mods i have and what i am running currently, (i just pulled the car out of hibernation)
RB20DET
FMIC
NGK iridium heat range 6 ***NEW***
divorced wastegate pipe
3"downpipe
3" testpipe (EGT sensor is hose clamped to the top of it as there is no bung, as people recommend when not using a cat)
3"exhaust
HKS intake
HKS atmospheric SSQV
new oil
new fuel filter
LUCAS FUEL TREATMENT (as it has been sitting all winter)
HUSKY 94 octane fuel
now what i need help with is shutting that code off whether it be looping the wire or just cutting the wires at the sensor and seperating them. does that code being thrown cause the ecu to run less fuel? Do i just need to break in the plugs? the sensor throws the code as soon as i start the engine and it WILL NOT go out. is there anything i can do to run more rich. i know its less efficient but it is a daily and i want it reliable...plus i am the "**** disturber" with my loud car on my quiet street...i might as well give the neighbors a fire show too. THANK YOU AND YOUR HELP IS GRRRRREAATLY APPRECIATED
RB20DET
FMIC
3"downpipe
3"exhaust
HKS intake
new oil
new fuel filter
