While replacing all my tomei cam cap studs with another $200 set, I found 1 that came out with full threads meaning the hole is stripped. Even with a new stud, it won't torque (stud starts lifting out at 1/3 of the minimum required torque.
So since the body around the hole is too small foe a helicoil, what's the best solution?
It's holding just barely and the other stud on that cap is good.
Do I:
Leave it and hope it holds at 10000rpm
Pull it out, clean it and reinstall with red locktite (don't care if it never comes out again; next time it's a new engine)
Reinstall it with JB weld, let it cure and torque nut after?
Drill hole slightly bigger, tap to whatever and JB weld in place
Pull engine out, part out and go rb30.
It's a new rb26, everything has been improved except for valves. Everything is done and waiting on this issue to start breaking in. Reason for fella if studs is that I had to pull out 8 of them to reduce the length and clear new baffles, found they were stretched beyond acceptable usage. Engine was Built by a respectable shop, no names to Protect the Guilty, rather than complain and fight I'll just swallow the $220 loss.
Thanks
Do I:
Thanks
