Aircare + BOV to atmosphere = HIGH HYDROCARBONS : Solution ?
It could work, but in the process it may raise your NOx emissions. Emissions are bad that way, reduce one raise another. This is only at BOV release, but aircare doesn't focus on readings during shifting, only at idle and 50-60km/h if i'm not mistaken.“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
You can always remove it (them) for the test and then put it back in again. Lot's of people run without BOVs (me included) so it won't be an issue for some short term gain at AirCare time.
I'm not sure if atmospheric BOV is your problem, I have air cared my car with an atmospheric for the past 3 years and results are below.
I always put the stock exhaust / cat in. During the tests they never activate the BOV since they shift at a lower rpm. They only test at a steady 50km/h and an idle test, both tests should not be releasing air.sigpic
4 door love.
As far as I know there's a decel fuel setting that can be adjusted (maybe Japanese tuning software only?).
But it looks like you can't access it from hand controller -
This domain name is available, own it today. Affordable payment options. Fast and professional service.
Doesn't seem to pop up in european? version of tuning software -
I have hunted and search ... nothing...
the only thing that is somewhat close to decel settings is in the idle adjustment..
2 idle levels - one for no A/C electrical load and one for A/C electrical load..
2 F/C recovery levels - one for each of the above..., this setting tells the Power FC when to recover from Fuel Cutoff on decel,, so the highger the RPM the sooner it'll resume fuel delivery...
