So yeah the title say that I got my motor running but after 5 seconds, it will simply dies. no idle at all. If I give him gas, that's fine. motor will run ''fine''.
However, we had to move the car so we started it maybe 3 minutes and now it takes mor elike 15 second before stalling. so could it be normal? like, at this time, I don't wantto f*ck up anything but if it's normal than we will continue to press on the gaz for the next 20 kms and should be good after or not?
So question is.. does rebuild motor need to be ''centered'' by running a couple of kms before driving fine or should they drive fine right off the first crank?
Now, 2 peoples told me about TPS, IDLE IAAC valve ( obviously!),maf,injector wiring,coilpack.
Everything was runninf fine when we pull out the motor so worst case, someone dropped a piece on the floor, I dunno.. but beside this, I can't see why any of these pieces could of been broken when they were running just fine 3 months ago.
Thanks for your times.
