Originally posted by bobbo
View Post
And by DD I meant street since without the thermostat you might not get enough heat into the oil from simply idling. Without enough heat it'll fail to keep at running temp.
Originally posted by cortexx
View Post
With the water to oil exchanger you get an additional heat input into the oil if the oil temp is < water temp. But if the water loses enough heat (high differencial between oil and water) through the transfer its temperature will drop in the process.
