Howdy folks, the gasoline in my GTS-T's gas tank is a couple years old, so I want to remove it all and put fresh gas in before starting up the rebuilt engine. I was planning on activating the fuel pump to run and pump all the old gas out into a jerry can via the fuel line in the engine bay that comes off the fuel filter. couple questions about doing this safely.
1- can I just pull the fuel pump relay and jump the 2 pins that connect to activate the pump to get the fuel pump running? will this run it nonstop?
2- is it safe/ok for the fuel pump to do this for the length of time it would take to drain half a tank of gas? could I do it in a couple spurts instead?
