how do they work, is it worth it to get/replace either? thanks!
how do ecu's and boost controllers work?
I agree with the ahole on this one.Originally posted by nimblestix View PostCall me an a-hole but honestly this should be Googled before posted. Sorry, stop trolling.
Sent from my Galaxy Nexus using Tapatalk
Double track drift, yo.
(o▫o sκylιnε o▫o)
Explaining how an ECU works would take pages, so buy this book and similar books -Originally posted by Sri-LanKING View Posthow do they work, is it worth it to get/replace either? thanks!
Should help you to understand the basics of how a ECU, sensors, etc works. Then there's computer code which is alot more complex.
Stock ECU is worth retuning (Nistune) or replacing with an aftermarket ECU (depends on your budget) when adding mods like intake, exhaust, etc due to those mods affect how much ignition timing, fuel a engine needs.
With boost controllers, read boost controller manuals, as it explains how they work. Also you have to understand how a wastegate works. That's both internal, external wastegates. More advanced boost controllers (more expensive) can do the basics of most boost controllers + adjust boost level based on rpm, throttle position, gear, drop boost level if car wheelspins, etc.
Boost controller is worth it if want to reach full boost quicker or the opposite, drop boost level (to wastegate spring pressure) or raise boost level, helps to get rid of boost spikes, improves acceleration, reduce wheelspin (more expensive boost controller), etc.RESPONSE MONSTER
agreed. Generation Y is now fading to generation laZy.Originally posted by BrianV8 View Posthaha I've learned over the years google doesn't suck you just have to know how to ask it lol.
Search first then narrow down your curiousity to a more specific question.
Asking how an ecu and boost controller work and why you need them is like asking how a human body works and why it needs food and water to survive. There is no "quick" answer.
