so was cleaning my engine bay and relocated a couple things, simple unclip and reclip
I moved my injector resistor pack inside my firewall beside my ecu. to see if everything was working fine I started my car while the resistor pack was still on the carpet of my car.
after a minute of running I shut the car off so it didn't get too hot for the rest of the cleaning, went to restart my car afterwards and it wouldn't run anymore, it would turn over but I would get nothing back
ends up I dont have fuel anymore, everything else checked out fine, fuel pump,coil packs, spark plugs
Could I have blown the injector resistor pack by not grounding the whole unit down?
when i test it with a test light i get a constant light on but no fuel is making its way into the cylinder, could I have blown the injectors?
I am getting 3 ohms resistance threw all the injectors and and 3 ohms from the injector clip when the key is turned on
if anyone has seen or heard this issue I would like to hear your feedback
thanks,
Frank
thanks,
Frank
