Oil filter for Greddy oil cooler sandwich plate.
  • Oil filter for Greddy oil cooler sandwich plate.
    So I have finally gotten around to installing my oil cooler and the regulare oil filter (15208-60U00) is too large, does anyone have the part number for a smaller filter that fits? I have searched and have come up with the following:
    1) 85-87 Toyota Corolla GTS oil filter
    2) Pitwork Big Size for BNr32
    3) Greddy SX-03 - seems small at 65mm diameter
    Thanks guys!
    Colin
    We have the Greddy in stock. They are OEM fitment but have a short stance. I can measure one for you if you want the exact measurements.
    RightDrive Inc. Parts Manager
      Thanks Daryl. It's not the height that's the issue, it is the diameter, the oem filter Is about 83mm diameter, but the thermostatic sandwich plate needs a slightly smaller diameter filter to not interfere with the angled part where the ports are.
        Have you looked at the 300zx ones? They make a smaller version that could possibly fit. Try looking at that one
          Ah I see, I can measure the diameter of the Greddy one and see. Is the Greddy kit you are using universal or R33 specific?
            Universal I believe.
              Colin if your having problems try looking here. This guy was sent a smaller one with his kit and it was a 34. No need to spend 60$ for a filter when this should work. Hope this helps:
              juz got oil filter and maybe i got the wrong un? i got a r32 gtr with oil cooler and relocation kit...it got the usual blue oil filter bought genuine nissan oil filter, box sez fits rb26dett 10/99- its white Is this oil filter the right one? just it looks too tiny to fit...lol :D
                Yes, the Corolla filter will work as well as K&N HP-1003, if you can't find the Corolla filter you can use 92 4 cyc Camry filter (PH4967 for Fram part no.). What's more critical with cross referencing filters are the thread size (3/4 -16) and the gasket diameter. For K&N filter the HP-1003 filter will fit both the Corolla and Camry but if you compare the Fram Ph4967 with their Corolla (PH2951) you'll see that the Camry filter is slightly smaller but the thread is the same and the gasket is almost the same. Incidentally K&N now have a K&N washable / reusable oil filter and the part no. is SS-1003.
                  The Greddy is 22cm in diameter if that helps at all.
                    napa gold 1396
                      22 cm? That seems a tad big...
