I bought a set of polished aluminum wheels and they have a few scratches around the outer rim. I tried the Mothers Mag and Aluminum polish but all it seemed to do was shine them up pretty well. Does anyone have any suggestions for a polish or compound that will remove the scratches?
Aluminum Polish Suggestions
polished or clear coated?Need detailing done to your car? I'm open to travel to detail your car :
a regular metal polish wont remove wetsand marks.Originally posted by Supraclean View PostWetsand 2000 grit. Then hit it with metal polish.
Sent from my BlackBerry 9700 using TapatalkNeed detailing done to your car? I'm open to travel to detail your car :
rub some metal polish if the towel turn black. it's bare metal. if it,s white, it's clear coated.
You gonna have to wet-sand at 1500-2000 depending on scratches, up to I would say 3000, using criss-cross pattern. Then you need a POWERFUL drill with a wool cutting sphere pad with some black and greend compound. then you can finish off with some rouge and then metal polish..
you see, you need at least 60$ in material + about 3-4hrs per wheel. be ready.Need detailing done to your car? I'm open to travel to detail your car :
I have two sets of these Modena in 17 inch and they are polished lip and not clean coated. The interesting part is that the set that came with my GTR has diamond cut lips (very fine grooves) and my spare set has polished lips. I have air tools and a 5 hp compressor and I used nylon grinding pads to remove the groves on my original set first, next I used nylon sanding pads from 3m with medium then fine. After that I used a polishing kit and finish off with Mother's wheel polish.Originally posted by Slider15 View PostIm not sure if they are polished or clear coated now that you mention it. They are Autostrada Modena's if that helps.
