EDIT: fixed it! ended up that it was leaking pressure in the tank from a bad connection or hose. replaced both soft lines in the tank and 4 under the hood. cars running/boosting great now.
1994 gts-25t
walbro 255lph
sard fpr
.8 bar
fmic
stock ecu
HKS SSQV BOV
on the wideband im seeing 14's - 15's at idle and normal driving which is good but under boost im seeing 11's - 12's, is it normal to be running this lean under boost? I tried swapping the stock fpr back on and car was idling in 16's so i put the sard back on. Its set at 35psi with vacuum, 43psi w/o vacuum. It is a rising rate fpr.
other question is since i have installed the fmic i have noticed while cruising on the highway if i give it a bit of gas to pass someone and the turbo spools up just a bit (something like .2 bar) then the bov will release and just after it releases the engine sometimes kind of pauses or almost dies it seems and it feels like i hit extremely strong head on wind. enough to knock your head forward. only pauses for a second and only does this when it releases at very low boost and has only started doing this after i installed the fmic. I have tested and only had 1 intake leak on the fmic intake coupler and it was sealed up immediately and made no difference.
1994 gts-25t
walbro 255lph
sard fpr
.8 bar
fmic
stock ecu
HKS SSQV BOV
